Surfriding Bumped the bottom and boom
Joined
Jan 2, 2017
Erie, PA
Bumped the bottom of the lake pretty hard after a big nose stab this past Sunday. This is the result. I was running rhaas mounts and Kenny keepers. None of the mounts broke and the hull didn’t crack. None of the motor mount inserts failed either. I’m thinking that the mounts didn’t flex enough on impact so the stress was transferred to the engine??? Theres a little deto in the cylinder that failed but I don’t believe that was the root cause of the failure.
long beach local
long beach local
Joined
Sep 24, 2012
Az
Stroker crank with spacer plate maybe the dowel pins are not long enough and left more room for it to move ? JB weld ? Sorry probably not funny
Joined
Jan 2, 2017
Erie, PA
The motor only has 2 light seasons on it and ran great right up until that hit. The other rod and crank bearings seem to be in good shape. I would hope an ADR crank held up longer than it did
Sent from my iPhone using Tapatalk Pro
Zero Client
BeerrroooOOOT!!!
Joined
Sep 27, 2013
Douglasville, GA
Dang man. What compression were you running? What CR? Pump gas? Squish relief? That rear piston was also taking a beating. Also look at the rear connecting rod - it wasn't happy at all around the bottom bearing. It should not have turned black - Black would be overheating as shown by the carbon around the rod at the bottom bearing. I bet the same black carbon might be seen underside of the piston as well as the front rod/piston. Not good for pistons nor crank!
