IMPROS Hooker
iptamenos
Flipping Around !!!
Greece
11/17 Hooker
868cc dasa pv 8 mm 85.5mm freestyle ported
B Pipe mod
MSD Enhancer with jss ignition coils
tbm Lightened Flywheel
duall novi's
185 psi
tbm cone
i saw difference from my old prop skat 14-19 3 mm setback
hooker give me more low now my superjet flip with more power i lost top end.
John
tor*p*do
Squarenose FTW
NW NC
I am now running my 10/16 hooker with a ported 61x 701
46 mm Mik MSD Mod Bpipe
in my SN
very happy! :Banane01: :Banane01: :Banane01: :Banane01:
Rn 2003 SJ
10/16 and 9/15 Hooker stubby cone stock pump stock 64x nozzle with Trim
stock 760 64x/64x type 4 pipe dual carbs ada head 190 psi I think with this setup and the 10/16 prop its a little laggy on the bottom end. the 9/15 seems to be the hot ticket it had to go back due to sucking up something and dammaging the prop
2010 Stunt hull
10/16 will be in this set up with a stubby cone stock 64x nozzle with Trim
new motor will be a Lamey 5mm 809cc motor 190 psi 46 mm carbs B pipe mod chamber boyseen reeds 64x lightweight flywheel cold fusion couplers will let you know how this set up works.....
300SX running 140 kawasaki pump (254 lb ski)
Jetmaniac / Blue 718
b pipe, atp waterbox
10/16 spun like crazy - now for sale
11/17 felt almost right - now for sale
Bought a used 140 mag pump, it came with a 12/17 swirl Works perfect.
I will say side by side the hooker and the c-75 swirl look identical
Tuscaloosa, AL
LOL I was seeing "Peach"........ LOL. Oh man, search through everybodys post and try and find one close. Assuming you have a DASA 1100. May want to contact them on recommended pitch. Or try Tricky1. he may can put you close.
Croatia
After many hours of testing i find best prop. Solas 12/18 was great but no power in top end so i make my ideal prop. From xl 700 155 prop 11/14 i cut on 144 and repitced on 11/20. Amazing power
Mesa AZ
10/16 Hooker
Rickter FS2 Evo
701 62T Non ported
B-Pipe(tuned awesome)
Protec Intake Manifold
44mm Dual SBN Carbs(tuned awesome)
vForce3 Reeds
ADA 195 psi Girdled HEad
Stock CDI
H20 designs Water Box(Killer!)
Slightly lightened Flywheel(6 oz. by group K)
Stock 144mm pump All da way!
RRP trim system
RRP Intake grate
HOLY CRAP! The thrill of riding is upon me!
(Granted still chasing bigger power)
