Ironmaster Adjustable Dumbbell Pair with Stand - $300 (Cypress)
Beautiful Pair of Ironmaster Quick-Lock Dumbbells with Stand in Excellent Condition. Always kept Indoors.
This is a Pair of 55lb Dumbells that can be quickly adjusted from 5 lbs up to 55lbs each.
Each Handle weighs 5lbs and each Locking Screw weighs 2.5lbs, so you can start at 5lbs, then 10lbs, then 15lbs and so forth up to 55lbs. On Pair does 5lbs to 55lbs. Pretty cool space saver.
Each Dumbbell comes with 8 x 5.0lb Plates(40lbs) and 2 x 2.5lb Plates(5lbs). So 40lbs + 5lb + Handle + 2 Lock Screws = 55lbs.
Two extra additional 5lb Plates included. That's an extra 10lbs on top of the 55lb DBs (Total=120lbs)
This Ironmaster Dumbbell and Stand set-up normally goes for $600 plus Shipping costs.
Buy it for only $300 FIRM. This is a great deal, and if you can't recognize a great deal when you see one, move on. Will not negotiate. Price is rock bottom. Price will go up in the Spring.
Note: A new 45lb DB Set goes for $400 plus Shipping and doesn't even include the Stand.
