Ive been trying to reach Tim at novi but haven't had much luck.
Throttle plates are like new but there is still play in the inner bore. The novis are bored very thin towards one side of the bore so I figure someone here has seen this before. The plates have started to break away the metal by the throttle shaft exposing the bushing. I tried adding another nylon washer between the eclip and the carb body but then the plate just catches.
Not sure if you can just grind the loose pieces out, shim it between the eclip and carb body(or ditch the eclip and use a collar clamp to slightly pull the throttle plate to one side instead.) Plate may have a slight gap between the bore and the other sides throttle plate though. Or somehow put one of the nylon washers between the throttle plate and carb bore.
Thoughts?
Or are these carbs junk.
Thoughts?
