Shaft binding after pump rebuild, plus tips & lessons
Joined
Sep 16, 2014
Lake Anna, VA
Caliper readings. Posting these for reference more than anything. Though if anyone has something to compare against, let me know if something’s not right.
42.05mm Solas hub ID
42.10mm OEM hub ID
24.94mm shaft OD where washer sits
41.99mm washer OD
20.67mm washer ID
25.11mm washer notch ID
5.01mm washer thickness
3.38mm washer notch depth
Joined
Jan 26, 2014
Also note, that if the Washer is not flat and perpendicular to the Shaft, it can bind with tremendous force.
This odd feature, a non-perpendicular Washer, is used to keep Pipe Jack Stand Tubes in place and can hold an amazing amount of weight.
The non-perpendicular Washer in a Pipe Jack Stand is called a Lock Washer. It is virtually impossible to move the Jack Tube down without first making the Washer perpendicular to the Shaft. Then it will slide.
eastcoastjumper
James
Joined
Sep 10, 2012
Long Island
I have assembled a dozen solas 144 and 148 pumps and have never used the oem washer behind the prop. I have always used aftermarket washers. The oem washer with the rubber binds and rubs against the seals, or bottoms out like youre experiencing and locks up the pump.
Also with fresh seals the shaft isnt going to spin fast without resistance. What you're feeling is normal.
Get a few different thickness washers from jetmaniac and reinstall your impeller.
Sent from my SM-N970U using Tapatalk
