- Granbury, TX
I bought my square back in December of 2008. It was a bit of a basket case but had a running 650. I ended up tearing it down, reinforcing the engine bay, painting the ski and adding a shortened RN pole. Also added a Protec Pipe and random aftermarket stainless impeller. The build was completed April 2009 I ran it like that until I threw in a 62t/61x motor and a factory pipe (with a few other goodies) in 2012 Around the same time, I did the hood mod and glassed over the fuel door on the nose piece (which was destroyed a few years later and replaced by a CarterB piece). It's always been a super reliable ski. In 2018 I pulled it out to go to the lake and realized how much it was finally showing its age and needed some TLC. I started collecting parts about that time but had no extra time to actually start the build.
The plans for the build:
-Tom 21 tubbies
-Hurricane foot holds/wide tray
-Upgrade exhaust to RN diameter from the water box to the hull exit
-Glass up all of the wear and tear from 10 years of thrashing
-Refresh everything that needs it (rebuild pump, new cables, rebuild carbs, replace wrist pin bearings etc)
-New Paint and graphics
-New turf
This is what it looked like when I started the tear down in November of 2019:
Just about everything pulled and started to remove all of the turf:
-Tom 21 tubbies
-New turf
