Bending the prop sounds like a good idea 12/17 sounds too tall for a 701 if bottom end is what you desire. Making sure it’s tuned right is most important and making sure the pump is hooking up.
FCV on the stinger may help, best bang for the buck would be to send the impeller to impros to repitch it, or get a hooker 9/15. Zeeltronics setup will significantly increase your torque and probably be around the same price as an ada head.
Nice improvement of your SN I like the modern graphics.The 61x is a good little motor ,if it were me I would spend the money on the pump first repitch the prop lower or get a swirl and even go 8/16 really wake that little 701 up . Even find a mag pump good Intake and make what horsepower you have efficient. Then if you’re anything like me try something else zeel whatever I can’t help myself ether lol.
