This is the front mount plate
Looks like you used the different 155mm pump like those in gp1200r. These pumps are different the wb2, gp1200, raider 1100 pumps. That is why the pump seal didnt fit.
you sure on that chief? The bearings are similar, either will fit the 144mm driveshaft.
He is correct. The 155mm pumps use dbl row bearing in the front and sgl row in the rear.
what yr they start putting 155mm pumps in the raiders
All raider 1100's have the 155mm pump. 701/760 raiders are 144mm.
