Purchased somewhat of a "basket case" 91 X2. Starts & runs badly (Chitty Chitty bang BOOM). Everything under hood is no mystery, I got that but the pump engine alignment, that's another matter. Don't have a clue where to start. Took a page out of the Sea Doo alignment procedure & fashioned a sleeve which inserts into shaft tunnel, slip fit into tunnel, slip fit over shaft = dead center. Is this where I base my alignment? Is that tunnel true to either/or? If not, Where is the "true" component/ position that I base the alignment from. Snap shot of where I'm at.
Shaft straight & true (per fact manual).
Shaft bearing loose & hanging.
No shim(s) @ motor mounts. Motor mount "appear" to be in good shape.
No shim(s) @ pump.
Coupling rubber good.
All evidence points toward that the motor/pump was pulled by previous owners & assembly was done in "Half Measure". That alright, I knew I was purchasing a basket case.
So knowing this. The procedure of alignment starts where????
Pics with parallax. Shaft favors 12:00 o clock straight up.
No shim(s) @ pump.
