Schmidty721
someone turf my rails
- WI
Please see post 16 & 18 and give me your opinions on this set up.
EDIT: Engine is not for sale. $350 is the price I paid.
I purchased the 62t/61x engine mademan9 had listed for sale not really knowing what I was getting. I needed a head and 61x cylinder for my current build and the price was right so I picked up the complete long block with dual 38's, carbon reeds, intake spacer, flywheel and a couple other little things.
Pulled the MRD girdled head off and see it has the domes cut back ~ 3mm.
Pull the cylinder off to and find an aftermarket crank. Per my measurement, it is a 73mm stroke. Cases are fully ported and epoxied. Cylinder looks to be re-sleeved with minor port work. Sleeve ports match the cylinder ports perfectly. Bore is 81.5 mm and both cylinder and pistons appear to be in great shape.
I spoke with a previous owner (not the engine builder) and he confirmed it was a stroker crank, but was unsure of the size. He claimed it came from a racer in California that rode for Yamaha. It was rebuilt with a new crank, fresh re-sleeved cylinder and top end with about 2 hours total on it. Orginal setup suposidly ran fuel injection and the orginal builder recommended he run a set of dual 46's... that ALL i know so far.
I need the experts help here. What the hell do I have????
