Custom/Hybrid Aircraftsalz 2011 Superfreak Badass Flatwater Build
Aircraftsalz
Thrust built Dasa Power
Off site
Well its been awhile since I updated my build.... Details
Removed XS1000 & Replaced with Dasa-Thrust built 16 mil 1100cc package... All tuning by Brian at Thrust
Sold the Flame! And Replaced with NEW MSD TL system
Today I built a MSD plate from an old over sized MSD SJ plate.... Cut my XM steering plate & did some welding. Now the Bars are moved 1 in fwd closer to the pivot bolt.
Why did you decide to replace the Flame with an MSD setup? Is the flywheel lighter?
*edit I should have read the whole thread, the MSD has a hotter spark. Why makes it hit harder off the bottom?
Aircraftsalz
Off site
The Flame FW is lighter right out of the box compared to MSD... But we fix that problem & it becomes lighter than the Flame...
We tested the Dasa 1100 with the Flame & then with the MSD... Performance was night & day... Ski runs smoother on the bottom end, Starts better, Made more power across the board... I've also rode Lucas's ski back to back with mine... Same setup's only I had the Flame & he had the MSD... Same results his motor had more snap (With less Advance at that)
I'm not saying the ATP Flame is a bad system, it has its problems just like MSD...I used it for 1 yr & worked some bugs out of the system & chris helped with making new flashes to correcting issues. The flame isn't for me with my FW ski, great surf ski TL...
If your going to ride saltwater everyday the flame is a better way to go, well until Thrust Innovations fixes the msd issue!
If you ride freshwater & want the most you can get out of a motor package you have to go MSD TL
Aircraftsalz
Off site
Still working on dialing in my ski 100% with the new Dasa power.... Gotta Thank Brian from Thrust innovations for all his help
Checkout my new FW cover
Also trying another mag pump set with this week, going bigger & setback even more....
Aircraftsalz
Off site
PLaying with pumps & some cooling lines today.... Going with 4 pissers now & not 4 lines Y into 2 1/2 pisser... Should clean up the engine a little
Checkout the Setback on this baby now
Aircraftsalz
Off site
I run (2) 1/2in cooling lines for the motor & a single 3/8 cooling line just for the pipe thats why you see so many fittings
But Yes it's a custom pump size, custom Setback, so you have to make tabs to bolt up the reduction, then you still have to extend the steering cable... Its a fun job, hope it works
... My Good buddy loaned it to me, I was spinning my other pump on the bottom still...
Going to the lake to ride tonight, will post a ride report later
Aircraftsalz
Off site
Playing with prop pitch ... Had it almost perfect with old pump, now bigger pump
But now I know where to go
I feel the bigger pump loads a lot more water and will be the way to go just gotta get the right prop
