Im rebuilding fx and installing a 765cc 62t motor with full mods... with this kawi conversiom work well? Anybody ever use the blowsion 144 direct bolt up?
The 144 is not much better than a Kawasaki conversion with a stock inlet.
where can i pick some up?
The o.d. of the bearings I mentioned above will fit in the Yamaha housing and the I.d. fits the zxi shaft. I picked mine up locally at a bearing shop for around $12 each.. Stainless double sealed. I've been running this setup for 3 years with no issues. It's been through a majorstorm too. bomber setup and no machining required.
