junkyardj
┌∩┐(◣_◢)┌∩┐
- barrie ont. canada
bang for the buck JetWorks 4mm BB is a killer setup if you have all the rest of the candy
The best motor will run like a turd if its not matched with all its components.
No need to spend all your money on a XS1000 if all you have to feed it is a single 38
I'm going to disagree with Gil - there's no need to be talking to your engine builder a lot if you explain what you want, settle on a budget, and the engine works right out of the box when you get it. My vote goes to XScream on that score. A great engine builder gets you the motor you want and gets you dialed in on all the other variables without a bunch of "try this prop" and "try that cone" and "maybe we need to re-jet". Chuck knows his motors inside and out, down to the point where I didn't even have to touch a mixture screw after I told him what altitude I ride at. Just bolt in and go.
X2 on the Paul's work I have a 82mm std stroke "701" that was build using Paul's recommendations & setting all I had to do was fine tuneMy point was that if the builder don't want to talk to me, I don't want to spend money with him. But your point is very valid, bolt in and go is the only way to go! After Art got me landed on MS109, the rest was easy and he sent it back to me dialed in and ready to go. Paul Lehr did a 701 motor for me that I never had to touch after install that was the best running 701s I have ridden to date. Paul's bang for the buck 701 pkg is impossible to beat!
(<1/8 turn) the carbs. the only work Paul did was port/bore the cylinders and lighten a flywheel, That and share his knowledge.
He has always been more than willing to help, with SOUND advise.
and as for bang for your buck i feel like I owe Paul.
:brap:X2 on the Paul's work I have a 82mm std stroke "701" that was build using Paul's recommendations & setting all I had to do was fine tune
I would love to get my hands on that lil blue notebook that he keeps!!!
If I were to ship my engine to someone and say, "make it rip" . What would they do to it and what it the approx price tag on something like that? I have a prop and B-Pipe already (Very simple I know).
Has anyone had this done recently and can offer some feedback or advice?
Also, How easy is it to rip the engine out and re-install it? Never tried it and was curious as to what the process was like...
Thanks
Again, depends entirely on your budget. I can only speak for what Jetworks does, but you could get your current 701 ported and leave it ay that, or Get the stock carbs modified on top of the port job, get some additional parts, or your could get the cases ported, big bore the cylinder, etc etc....
I recently tried out a near stock bore Jetworks ported 61X cylinder on X cases, and also a ported 717 61X/62T motor with modified dual 38's. Both of them were the strongest engines in that size/price class I've ever tried.
Question is, what's your budget?
