From Shorai:
"CCA Ratings for lead-acid don't translate well in comparison to SHorai LFX, because we typically hold up to 2V higher during cranking than an equivalent-rated lead-acid battery. Since it is WATTS that starts your vehicle (A*V), this means that we crank much better than our CCA specs indicate.
"Amps" never started a single motorcycle. Watts (V*A=W) start motorcycles. And batteries don't supply "CCA" in the real world; they supply the current drawn by a starter motor, which is based on the load on the motor, and the voltage delivered from battery to starter.
As for voltage, 12V is a "nominal" rating. A fully charged AGM will provide about 12.8V, a fully charged Shorai LFX about 14V.
Since lithium batteries start with a higher nominal voltage, and our LFX hold voltage under load better than the lead-acid we replace, we deliver more watts per CCA rating. As stated in our FAQ, if you are interested in actual cranking performance rather than a CCA rating designed for 12.8V lead-acid batteries, you can multiply our CCA by a factor of 1.5 for a closer comparison to lead-acid CCA ratings, in terms of delivered cranking speed.
To re-cap, CCA ratings were never intended to convey anything but the relative voltage performance of lead-acid batteries, under a given "real world" load. Since the voltage delivery of lead vs lithium can be very different, CCA ratings alone do not provide a full indicator of relative performance."
this is good news for me and my older Flame TL, because it quits sparking when cranking voltage drops below 10V
