Freestyle building a MICRO ned input on pipes that will fit
madscientist
chilling with these guys.
good old p'cola
i am building a micro and have a wdk 1200 on the bench to use. the motor itself will fit but the pipe will not. what are my options to put the 1200 in this hull?
the tnt chamber on a lamey fits great.
yamanube
This Is The Way
Staff member
Mandalor
Unless it is much wider than a superjet inside you won't fit a B pipe headpipe/mani with an adapter plate on the 66E. I think guys are running the powerfactor pipe in Micros, might be able to get that to work with a custom manifold. Either way, I highly doubt there is a bolt on solution.
N3vrSat1sfied
Military Member
Fort Worth, TX
Can you move that engine back? That would give you a lot more room. My aerial only has two inches between rear hood seal and rear cylinder
Sent from my iPad using Tapatalk
