Can someone please tell me what tis is???
S. FL
There is a brass tee off of my headpipe that looks like it goes into a checkvalve then into one of the headpipe screws??? any idea what this is for?? I bought the ski like this and the guy wasn't sure either!!
Thanks,
Sean
BombThreat
'Diggity
Johnstown, NY
Looks like someone drilled out the middle adjuster screw and installed either a normal 1/4" hose barb or a water injection fitting there. Filter is there so the tiny hole wont clog.
Pull the hose and see what they got goin on there
OCD Solutions
Rentz, GA
X2 for this one, I have the same setup except I don't run a filter and mine was installed in a brass sleeve fitted thru the waterjacket.
attachment.php
SUPERTUNE
Race Gas Rules
Clearwater Fl.
I'm pretty sure that's set up like what we ran in our Seadoo race setup, a external water injection fitting installed in a plugged water jacket hole.
The filter is for any debris that might clog it. More than likely it will have a main jet tapped in it, you'll know as soon as you pull off the hose.
Using jets is a better way to have a pipe water bleed than screws anyways, a lot more precise.
