Other Epic Timing Question
munki63
Epoxy is my duct tape
Canada
When making a epic curve will it be possable to damage the motor with an overly aggressive curve? If so what care should be taken when making a curve?
OCD Solutions
Rentz, GA
I would say the answer is yes, so start with a known curve and play from there.
I have bumped mine up very slowly after some experimentation and feedback from others.
If you advance the timing too much, you can cause detonation which will destroy your topend.
steve-uk
Manners cost nothing
Barrie - ontario
the standard curve on the EPIC is a great starting point
if you want pointers specific to your motor chris is happy to give advice too
what motor do you have?
munki63
Canada
It was more of a general question, I'm getting a curve from Xmetal might play with it after, but I would also like to run a retarded curve for hood tricks, just don't want to damage my new set-up
if you have to ask that question, you shouldn't mess with it. if xmetal sent you a tune it's prolly pretty close to being dialed in.
OCD Solutions
Rentz, GA
You may just be getting mixed up in your terminology. To tame down a curve, you are not retarding it, just not advancing it as far. Static timing is something like 21deg.
For istance, in my tamed down surf curve, I cap my timing advance at 25deg, where my strong curve goes as high as 32deg.
munki63
Canada
I have my own terminology lol, so for this thread let's use the terminology retarding
steve-uk
Barrie - ontario
Pump gas and I have no idea Xmetal is setting everything up
id run that one, chuck has some curves already worked out, x metal has been using the epics for some time now and know what they are doing
munki63
Canada
How does anyone learn anything if they don't ask any questions? Gotta start somewhere.
Thank you, there isn't any sort of guide with the program regarding what to or what not to do, I dont want to harm my engine I do want to have fun with the epics capabilities, some guidelines would be nice on what to do and what not to do
Aircraftsalz
Thrust built Dasa Power
Off site
Just play with it, you will know when you went to far, just listen to the motor & see how it feels.... I wouldn't go any further than 34-35 advance... Have fun with it
waxhead
wannabe backflipper
gold coast
I can only talk for my engines , but if you run the stock epic curve up on one of my setups you are likely to detonate your engine. I want the timing out alot sooner than on the stock epic curve. I also want the timing in alot sooner as well to make the engine come alive. This is on 98 octane we have in australia, I dont know what you are running in the usa but i believe its less octane than we have.
I would definetly order a cable when you order your ignition
dfw
He is going to blow it up following the trend. They always run best right before death.
