flatwater flip 701?
Tuscaloosa, AL
have you tried your motor setup with a "B" pipe?? may be able to get some bottom with this setup.
Malone is doing flat water flips on his Q8 with a stock SXR800 engine package with a Wetpipe.
cookerq62
Life's Been Good
Upper Bucks, PA
Nice work! Fix that starter and get after it. I've pancaked my bone stock machine off of freak setup wakes by mistake. Deep glassy water gives the best setup wakes.
Polish jet pilot
4aces4aces4aces4aces4aces
Warsaw, Poland
It looked good (timing, hop, etc)! Really with porting and maybe TL you should be able to get it done. This year I will try it too finally.
I must say I envy you just a bit :)
P.S. So how do you assess the help of the trim? REALLY needed?
right on man thanks! but im running the x metal trim system and as a system its veryyy nice im very happy with it. Now how much it helps.... Id like to say its a hugee difference but honestly i have not tried a ghost rider or a backflip without so i cant honestly say..... but i can tell you grabbing that extra lever gives ya a little more mental confindence if you know what i mean haha but it defently helps getting the nose up and also helps on with the setup wake. Im not aware of anyone doing a flatwater flip without trim....
The trim made ghostriders very easy even with a 701 here are a few i did that same day not the cleanest but was the first day I learned them.
