Hey Lerott,
If your sure it's not sucking air (mid shaft, pump seal, wear ring) , you can : go with a big intake grate, big pump cone, small reduction nozzle, fair out the pump ring area, set back the current prop 2mm from leading edge of stator veins if this doesn't work you need a bigger prop.
