Mile9c1
X-H2O.com
- Grand Rapids, MI
I don't see why flat tops would affect the basic function of the water screws. But every setup is different; too many variables to copy someone else's jetting.
freestylegeek said:Right here:
freestylegeek said:I would start almost dry (bottom screw open a tiny bit - verify with a garden hose)
superramjet said:full spectrums have the returns drilled out and run a jet in the return line. Are you returns restricted at all?
Yamah0 said:Thanx geek:wink:
Hmm... garden hose!!
Iv heard a mechanic here in my speck of the woods talk about that, but his engrish was velly hald to undelstan.... so i was just nodding my head yes yes, and what i gathered from him blabbering was how he used to like spraying his neighbors dog with a garden hose, or summin like dat:banghead:
Can u please explain the procedure, or is there a site or thread where i can read/learn about it?
Yamah0 said:Well i did what i had to do but no luck.
Question... Does compression affect the jetting?
My compression now is 225 but today im gonna swap out the domes and that should bring my comp down to around 185psi..
So do u think the jetting setup (135, 125, 2.3, 115) didnt work right cuz of the higher compression?
Does the engine run leaner with higher compression?
Also...If on my flat top setup the 28cc domes gave me 150psi and the 24cc gave me 225.. Is theres a way to calculate what exact size domes i need to get around 185 to 190psi ?
What compression are you guys running on ur flat top setup ?
Sorry for the gazillion questions.
I hate this:frown:
Zane...
Yamah0 said:Question... Does compression affect the jetting?
Yamah0 said:...What compression are you guys running on ur flat top setup ?...
freestylegeek said:I'm running an ADA head with 24cc domes and my compression is 185psi.
I am, however; running a ported Lamey cylinder...
When Paul says he'll get you through this, he will!
Trust in the master! :biggrin:
What? freestylegeek has a lamey? I couldn't tell. :wink:2nd nature said:must be nice to have that lamey.
Jr. Magoo's said:when the motor was assmbled, did you do a leak down test?
Did you do a squish test?
Exactly where is your timing & did you set it with a degree wheel.
rember, you are now using a flat-top & the piston timing Dimension is a little differant, you will need to compensate at the stator
Your jetting numbers are all over the place.
I'm waiting to get with Ed on your Full spec jetting. I will have that for you shortly.
Hang tough, I'll get you thru this & going in no time
Yamah0 said:Well.. no leak down test was done cuz i think non of the mechanics i know here do it or know about it. :banghead:
Squish test? Hell.. If i tell a mechanic here to do a squish test he'll prolly think im askin to date his daughter or talking bout some vegetable.:chairshot:
My timing is set at 0 but was not done with a degree wheel... same scenario as above.
I spoke with Ed yesterday and got all the correct jetting and tips for my FS.. so im gonna try it out today and recheck my compression with the 28cc i put back in. So we'll see.
Paul... what if i put the 24cc back in (225psi) and run two base gaskets?
Thanx for the support and all the help fellaz.
Zane
Zane...
