My new Envy
Ohio
Thanks all. Now I gotta figure out what to do about some kinda stickers or graphics.
Or just leave it as is and rip it!
ski4
gonzo
cleveland
sweet.
shoot........ if it's all in now why not just pull one bolt at a time ,
a few drops of loctite , torque and be done.:headbang:
don't risk going out and having a short day with a bolt backing out and something breaking.:bigok: you know your luck
get it all done right and enjoy the rest of the season trouble free
DOH!! Oh yea.....so one hose clamp and out comes the entire assembly.
I was thinking why not just weld it and ditch the coupler!!
you need flexibility in that spot according to FP. I asked about using another type of coupler and they said that coupler provides a flexing point and any stiffer material would cause problems...
Ohio
Flexibility for install purposes?
Why would it need to flex under operation?
SuperJETT
none
Because the engine vibrates/moves around a lot and the waterbox doesn't as much, so you need something to allow for movement. The headpipe/chamber coupler and stinger/waterbox hose do that.
Ohio
Ah ha. I see. That makes sense.
Man I wish I could just weld them together but that would kill resale value and I guess its not necessary anyway.
Ohio
I am an admitted known wrench hater!!:crying:
But this was worth it!! Just wanna make sure its as good as it can be so I don't have to wrench for 30 seconds or a minute or so.
Lakeman
Stand Up All The Way
Wichita, KS
I need to write them!!
Jeff said this is the first and only Superjet conversion evny.
Are you talking about using the Yamaha pump? I know others are using the yamaha based motors with the Kawi pumps. Using the Kawi pump eliminates the need to shim the pump is what I am understanding.
Did you get your pump all lined up as best you could? The drive shaft needs to be centered in the hole inside your hull. I have found this to be very difficult to get done in my Rev ski's.
Dale
Ohio
Yea the lack of locater pins makes it feel odd but mine lined up perfectly with the shims Jeff said to use.
Smurf made me perfect .125 shims from bar stock with a hole drilled to match my bolts.
This whole ski pretty much went right together but I moved like a snail and quadruple checked everything twice and still made a couple minor mistakes.
:261: Is it done yet? R U ready to ride? LOL... it looks awesome and I know you did an awesome job... cant wait to start on my SXR...
Now lets go riding:fing02:
Ohio
Thanks Rich. I am ready to help anyone build anything now. Everyone helped me so much that I know this Winter is gonna be hell in my garage!!
Just no more grinding/sanding carbon inside!!!!
I see at least 3 refoam jobs going down though:ugh2::dead1::grumble:
Oh and I will be on the water Sat or Sunday.
ski4
gonzo
cleveland
i am actually sorta excited to get mine done
for so long my nose stabs have been "flat" i think a lot is the wt of the ski.
and rolls will be easier again too. when a super jet weighs as much as a sxr
things are bad
and i HATE!!!!!!!!!!!!!!!!!!!!!! my foot holds hate hate hate
so im sorta stoked
:smokin:
