Nice progression and attention to detail! Could you go into a little more detail on the strap bracket you made up? Did you loop the strap through it then sew it, or just wedge it in there between the bracket and the turf? I'm also anxiously awaiting my tom21 hood - looks well built. I'm also having him make up the clean nosepiece attachment.
I looped it through the ratchet first and sewed it, at about center of my piece of strap. Then I looped it through the bracket and sewed the end of the strap. I used a "heavy duty" program/pattern on the sewing machine and made several passes. It was a b*tch, since the strap was so short. I also put some u-shaped rubber on all edges where the strap goes to reduce the risk of damage to it. I also sewed the entire lenght from the "y" to the end ,on both sides. I even melted the end and hammered it while hot to make it more durable. The ends that you see in front of the pole bracket are just folded double and sewed. I have done this in the past and it seems to hold up well. I hope that made it somewhat clearer?
Thanks for the compliments, good luck with your hood!
