need pictures of mcmaster carr headbolt
Dubs chops
livintit dot com
i senn a picture i thought superjett put up but now i cnat find it. i am wanting to use it for reference. also are you using a washer underneath the hex head bolt and how are you torquing them with the hex head?
hhh
they make "hex" sockets
images
Dubs chops
livintit dot com
thanks man. What did you use for washers under the hex heads? also my hardware came with a standard hex nut on the long girdle studs. will i need them if i get acorn nuts? i was wondering if they snugged up under the head to keep the studs from backing out?
