removed turf, cracks, opinions please
sneaky
a real mickelson
PNW
I peeled off my old turf, found a huge crack, the whole piece pulls up in the rear of the tray. :shooter3:
1. what do i or who do i need to do to fix this?
2. is all the foam inside the tray totally waterlogged bc of this?
3. this a common place to break?!
help! :banghead:
You can bet money on the foam being waterlogged.
Either glass over it and ride, or tear it out and refoam.
Wolf Child
Just Another Octard
All over C. FL
would it be possibly to drain some water if i stood it on the nose for a while? maybe used a space heater? :shooter3:
if you want my honest opinion...
you have the turf off, you have to glass it anyway. just defoam it and fix it right. it'll save you a ton of agrevation later on.
tor*p*do
Squarenose FTW
NW NC
x2. time to defoam.
look on the bright side- you can put in footholds while you are at it! :Banane09:
sneaky
a real mickelson
PNW
You know what the right way to do it is, right? :biggrin:
not exactly, i read crabs build and it looked pretty intense, cutting the tray up and refoaming. .
My origional plan was to just throw some turf on this year and then do footholds and reinforcing next year. . and returf then, sounds silly i know. but i've been working on the motor too and just didn't want to bite off too much seeing how summer is comming. .
Crab
thanks darin...noswad!
Seattle
Just give up and give it to me..........That stock foam is garbage, most don't realize its really what your standing on outside the pump tunnel.
sneaky
a real mickelson
PNW
It's not intense. Do it right. :biggthumpup:
:sneaky:
give the ski or the foam to you!?
Its really not that hard to defoam a ski grab some beers and go at it you will have it done in no time.
prob looking like the best way to go. i havn't had time to search for a TECH how to on doing it but hopefully there is one. . :arms:
WFO Speedracer
Alabama
Fear not the path you have chosen,use the force it will guide you.
If that dosen't work try a large screwdriver and a drill with a wire brush on it lol.
