jetskier79
I'm goin' for two
- San Diego, CA
I only browsed through this real quick......but i just wanted to interject and say that hydro-turf works great as a hood seal.
slut how much?
I just got off the phone with Britech.
samples on the way from them as well.
:headbang:
slut, how did you cut out of the padding, like 1 few strips to go all the way around, 4 for each side, etc??
oh wow, shoot us some pics when you get a chance
two pieces... one on the front lip and one to wrap around the rest. It's sooo tight that I have to sit on my hood to get it to seal after it sits in the garage all week w/ the hood off...
check this... instead of putting the padding in the intended spot on the front lip, I put it so the padding is actually on the little wall below the bracket... That way when you put the hood in the hooks and push it down to seal it the front side of the hood and the small wall area below the bracket pinch the gasket material so there can't be any water intrusion... The gasket on front wall is approx. 3" wide... up to the hood hooks from the original gasket area...
I rode for 1hr sunday and my motor never got wet.... yes... the top of my head still had the wd-40 on it... I was very impressed...
It's nice to see you are putting our product to good use.
Just a little info for you blaster riders, our hood seal gasket for the JS300,440and 550 fits the Blaster as well. I think you have to trim an inch or two for a good fit.
Mike@hydroturf
