The op was talking about replacing the selector, my suggestion was only aimed at a temporary quick-fix while waiting on a new part.
I apologize for giving info that could be a destination to another issue. It was late and I just fired it off without giving a solid disclaimer of a temporary $5 band-aid and not the correct thing to do for a permanent solution.
This forum being the wealth of resources that it is, a hack-fix has no business here. My apologies...
*#%@!^* WRONG ANSWER. if you T the on and reserve, its going to suck nothing but air as soon as the gas level gets down to the bottom of the on hose.
run a fuel line from the reserve barb on top of the tank, to the bottom fitting on the carb. cut the line in half and put in the fuel filter. plug the on line on top of the tank. done
Sent from my LG-H700 using Tapatalk
