I have slowly been cleaning some wear and tear and rebuilding my motor. its gonna be a 62t non ported case with oem 38s and a lightly ported 61x cyl i picked up that needed some love, with two broken ex studs and malled up ex threads. i drilled and taped it to take 62t hardware and bored 2 over to 83mm. with wiseco pistions and ada girdled head with 35cc domes. havnt checked compression yet...im not there yet.
the hood (24-7 "prototype"/practice) needed the most lovin with the liner popping out and some bubbles from the layup that needed to be filled, so i cleaned out all the damaged glass, layed in new and went to sanding. the pole is a umi rn pole with bearing -1plate and 0*bars that i traded some oem parts and labor for.
it is all ready for paint and heres where i want some feed back. i want to go with house of kolor chartreuse neon on the hood, and pole and nose piece get i was thinking red neon? i havnt seen any of this color series in person except for the chartreuse and its wild.
http://ep.yimg.com/ca/I/yhst-48512690786367_2247_116462481 this is the color chart. what do you guys think?
