waxhead
wannabe backflipper
- gold coast
Wedoseadoo , your clearly an idiot , go away
also its easy to build an engine thats good for just 1 second brapps much harder to make an engine that a customer can hold flat out for 40 secs +
like a race engine
the poll question should read:
Putting a single carb on a 62t case will sieze a motor on WOT runs.
Can't edit the poll question.
i have been using a single 48mm/62t for a few years now with no problems
Yeah but when that you bueat engine melts down due to to much compression , to much timing or badly mismatched combinations of a hole lot of things then its easy to say you held it wot with your single carb
like a race engine
up the compression some more and crank some more timing into it
you will achieve your goal
