Waverunner wave venture 701 engine problem
I have a 701 Waverunner 3 seaters, I just check the compression and I have 150 PSI on both cylinders, the spark looks very good on both spark plug, the engine start very easily but when I give a little bit a gas the engine dies, ,
the battery is fully charge,
the gas tank is full,
the engine was well winterized ,
I open the carburetor on 2018 they were in very good shape, I only put premium fuel and Av gas for the last tank of the season ,
thank you for your help,
Mike W
Infidel
North Florida
Did you put fuel stabilizer in your tank when you winterized? If so, did you run it so the treated fuel ran through the carbs?
Oh YEs I did put it and then I when 5 minutes in the water for the gas stabilizer to go through the carbs and also put Av gas because the gas is good for 2 years before it starts to deteriorate
Mike W
Infidel
North Florida
Make sure your fuel tank check valve is functioning correctly. If it’s bad, it will let the entire system pressurize and cause this. I just went through this a few months ago. Loosen your fuel cap to let the pressure out of the tank. If it runs like it should than that’s your problem.
