- indjana
Where did you buy this stuff?
Got it off fleabay
Put my motor together tonight. Having issues with starter / solenoid. Doesn't always want to crank. Sometimes just clicks. Tried two different starters cleaned grounds. When it cranks it cranks hard and gets a perfect 150 psi on cylinder. But when I try the other cylinder I can only get it to half ass crank and get about 80-90 psi. Makes no sense to me. Does this with both starters . Turns perfect by hand it's not binding. It cranks so hard on the one cylinder it wants to jump off the bench. The other gets a weak ass crank. I'm stumped .
Have you ran the motor at all to seat the rings?
poor little square feel into the hands of a chopper, cropper, stripper, chipper. i would have washed that hydroturf and awesome old graphics, painted the handpole pad and dropped a stock 701 in it and ridden it as is. did you pick it up in a white van with no windows, you molester of squares?
that was a nice find. those ambiguous ads always get my heart racing haha
Starter soilend was going bad replaced it. Compression is now 120 and 150. Should I try and figure out what's going on with it or run it and let them seat
What do you guys suggest oil ratio for break in? I've got a hookup on klotz so I run their ski craft oil.
even if its still tcw-3?
