227
Its all about the surf!
- Oceanside, CA
REFOAMING WITH OEM STYLE NOSE FOAM
I have been avoiding that terrible subject of removing and replacing my water logged hull foam for as long as I can now, but its finally caught up to me. This is a nasty job, and I only want to have to do it once, so after reading several threads of all the pros and cons for refoam options, (Ping pong balls, expanded Polystyrene, etc) I decided that the best option would be to go with the same foam as the OEM nose piece is made of, as it is both water and gasoline/oil proof. After some exhaustive research, I finally found out exactly what type of foam that nose piece is made of. The Foam is called "Beaded Polypropylene" (BPP) I believe it is also called "Expanded Polypropylene" (EPP). Like already mentioned, Polypropylene is a closed cell foam which is both water and gasoline/oil proof. It looks identical to expanded polystyrene, except it is slightly heavier. When I say slightly I mean oz not lbs. It cannot be poured like a two part foam, as it comes in a sheet, so it will have to be custom cut/fitted into the rear cavity of your ski when doing your refoam. From the quotes I've received, enough BPP Foam to do a ski will cost around $50.00 which is cheap considering you will only have to do it once. For all you scavenger guys on a budget who live near the beach or a junkyard, BPP is the same stuff they use for body board cores and it's also used in the bumpers of newer cars.
To learn more GOOGLE Polypropylene or read about it here
http://www.epp.com/
You can get it here
http://www.usplastic.com/catalog/item.aspx?sku=45707
Or here
http://www.markofoam.com/
http://www.epp.com/
You can get it here
Or here
