Superjet build up, some advice needed.
have a 99 SJ
1. solas 13/15
2. worx intake grate
3. stock ride plate
4. 3-4" stock pole shortened
5. 0 degrees bars
6. UMI spring
7. factory B pipe
8. Bilge 500 pump
9. Blowsion mat kit with footholds
a few questions
i would like to take my jet out to the ocean a few times, are there any other upgrades that im missing for safety of my jet?
can the stock nossle be upgraded or shortened, or another installed for tighter turn angle?
Does anyone know where i can get OEM graphics that were used on superjets from 96-present?
DAG
Charlotte, NC
reinforce hull never hurts in the surf.
also it would be cheaper to get some custom graphics made by some of the boards sponsors. OEM is retarded.
If your looking to tighten your turn angle, you can relocate the pivot ball that attaches to the steering cable. If your viewing the ski from the rear, disconnect the cable, unscrew the pivot and drill a hole closer to the nozzle and retap the hole so that the pivot will screw in at the new hole. This will give you a little quicker steering to the left. Helpfull if you barrel roll to the left.
Also ensure the steering nipple at the handle pole end is screwed into the furtherest OUT hole - these too things combined get you more turn.
Blowsion sell an awesome stock modded nozzle on an exchange basis - this will sort you out with LOADS of throw:
http://www.blowsion.com/detail.asp?PRODUCT_ID=YASJAC666
One of the cheapest and best mods out there..
Enjoy - jetski mods are like Crack!...:Banane01:
Phill
v Check out Little Matt_E
Kennewick, WA
ehhh I was just painting:1244: :1244: :1244:
I just saw the n and a number at the end and must have thought it was butch......I thought that shoud have been stuff butch would have known:biggrin:
I think I will go back to painting:biggthumpup:
Sospikey
Trying to get upside down
Sweden
Limiting rope!!!
Hood straps?
The oem graphics? Try rivayamaha's parts finder. However, I would recommend Exoticsigns.com instead.
Works 201 $115 at www.motorcyclecity.com
Impeller $193 13/17 at www.parkeryamaha.com
0 degrees UMI bars $43 at www.parkeryamaha.com
Grips $20 at www.legdrags.com
Umi Turn plate $154 at www.motorcyclecity.com
Umi pole spring $40 www.legdrags.com
Bilge Sano switch $74 at www.jetskiunlimited.com
B factory pipe $649 www.247innovations.com
Bilge pump brackets x2 $20 at www.motorcyclecity.com
Flush kit $13 at www.parkeryamaha.com
Limiting rope $39 at www.jetskiunlimited.com
Dakine footstraps $39 at www.skisurfing.com
Y
yamaslut
Guest
Call Kevin Collins at Legdrag, I bet he beats all those prices...
www.legdrag.com
send him that list and see what he can do for ya... :biggthumpup:
Y
yamaslut
Guest
Nick, how good is the skat 12/17 on speed? i dont want to sacrifice that top speed for those flat water days
top speed, what is that???
I know nothing about top speed....
seriously, I can't help ya there at all...
