Stroker question
jura
X
Belgium
Is it possible to stroke a stock 701 without touching the boresize?
What should be needed and what's involved?
Should it be worth the effort?
Thanks.
jura
X
Belgium
Yes... it can be done.
What size crank did you want to install?
No idea, I was just wondering if it is possible and what stuff I should need.
Cylinder mods? Spacer plate? Domes or head? Crank case mods?
A 10mm stroker gives about 800cc I think, why not?
Price difference between a 4/6/8/10mm crank?
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Anything more than 4mm of stroke is a waste of time without re-sleeving for freeride/freestyle horsepower. If you going for top end OK maybe up to a 5mm stroke. Strict port mapping must be followed when building a stroker, so custom re-sleeving is a must with most engine stroker packages.
crammit442
makin' legs
here
I hope freestylegeek is not reading this.:bigeyes: He's running an 8mm stroke/81mm bore combo. He says he thinks it's making around 160 horsepower based on comparison to Paul's motors with claims of 180/190/210 horsepower. Interesting.:thinking:
Charles
freestylegeek
waiting...
Grand Rapids, MI
I hope freestylegeek is not reading this. He's running an 8mm stroke/81mm bore combo. He says he thinks it's making 160 horsepower based on comparison to Paul's 180/190/210 horsepower motors. Interesting.
Charles
I am indeed reading this Charles, and I totally agree with Chuckie. Stroker's require a 'Package' approch when building them.
Charles
I think Chuckie was talking about stroking stock cylinders.
