xmetal waterbox question/s
Ericfox
Do it twice?That's DooDoo
I am going to get the xmetal waterbox with front exhaust.
I want to get rid of the rear exhaust... what do you guys to do get rid of the rear exhaust? Is it better to leave it in? Dont know if I want to install a scupper valve..... I imagine that is an option though to fill the hole....
hope you don't ride on a lake cuz everyone will hate you in no time, built mine for the ocean tested and tuned on the lake 3 times and no more friends at the marina i personally think it sounds awesome. I added one ways out the back.
I hope you don't ride in areas that have any people with hearing around.
XMW WB + Front only exhaust = guaran'f'n'teed to piss people off.
Y
yamaslut
Guest
I would fill the hole w/ foam and glass over it after removing the pipe, of course... that's what I did
tor*p*do
Squarenose FTW
NW NC
I didnt say I didnt like it
just that "people" on my lake would crucify me if I was riding a ski that sounded like that!
Ericfox
Hmmm.... I see what you guys are saying... I watched the videos in that thread, and now will only do the rear exhaust with the x-metal box if I get it at all.... do you guys recommend this waterbox, or maybe another? Maybe just stick with the stocker.... definately I think the front exhaust might not be the best idea for the lakes I ride at....
Yay bandwagon! :biggthumpup:
I wouldn't have an XMW waterbox if I hadn't gotten a good deal on mine.
It is noticably lighter than stock (not just in your hand, but actual riding)
Ericfox
couldnt you just weld a round piece of aluminum on there? and then just cut it off if you ever want to use it again? I guess the rubber piece should hold ok though.... no leaks?
I wouldn't. Why do it permanently, it could hurt resale value.
#ZERO
Beach Bum
Florida - U.S.A.
I would use the front exhaust with a stock waterbox to cut down on the noise factor.
I used four layers of 18oz. biaxial fiberglass inside of the hull and three layers of chopped glass on the outside with 3:1 epoxy resin to fill the exhaust hole.
