WAB
salty nuts
- coastal GA
Anybody ever switched out just the chambers to see the difference?
Which is supposed to be better for low end?
The limited is better for low end (by design and function). The difference will depend on overall motor setup...and possibly at the expense elsewhere.WAB said:Which is supposed to be better for low end?
Matt_E said:WAB, if you have a 62T cyl, and he's got a 61x cyl, the exhaust ports are not at "pretty much the same height".
The 61x would develop the power sooner than yours, I would think.
WAB said:It's too wet, I know; thought it would be safer that way. I've been running it with the bottom screw open at least a half turn, middle closed, and top one open about 2 turns I think.
I have the stator set advanced (counterclockwise) 2-3mm. Stock head.
yamasaki said:3mm advanced is what i ran my last 760 motor at. fook it, take it to 4-5mm... :biggrin:
TXJFrosty said:Not too threadjack here, but... how much timing advance can you safely go with this setup or should I not even bother? And what implications for reliability and longevity are there with doing so?
2001 Superjet -
OEM 701 cylinder - Magoo freeride ported
Factory "B" mod pipe
ADA head w/35cc domes ~175-180 psi
stock flywheel (for now)
stock ignition
Pro-Tec modified CDI - adjustable rev limiter
stock 38's (for now - going to put on a set of 44's this fall)
dual cooling
13/17 solas with 3mm cutback
bore reduction nozzle
thanks for the info...
