Mikuni Spring Color & Popoff Pop Off Chart
Shonuff
I've got the glow
Memphis
115 gram = gold spring
95 gram = dull silver spring
80 gram = black spring
65 gram = shiny silver spring
115 - Mikuni Reference Number 730-03030
95 - Mikuni Reference Number 730-03033
80 - Mikuni Reference Number 730-03027-T
65 - Mikuni Reference Number 730-03027
Huge props to Greenhulk's RX951
DAG
Charlotte, NC
I took me a like 10 pictures to get one in focus but here they are...
Left to Right: 115g, 95g, 80g, 65g
All Genuine Mikuni
Two notes... seems the 115g are not gold anymore.....
The 95g are wound backwards as stated before
Hope this helps....
Buy lots of springs! they never read what they should..... grrrr!
spring w/pic thanks to 2lick
Indeed, it gets asked way too often.
I am tired of linking the manual.
Now I can just link the Tech FAQ.
:biggrin:
michael950
for me to POOP on!
Houston, TX
NOTE: It is recommended that you do not use too large a needle valve
for your application. Many tuners recommend using a 2.3 or 2.5 needle
valve in all cases. Actually, we recommended using the smallest needle
valve that gives you the correct pop-off pressure for your engine. A 1.5
needle valve can flow the maximum amount of fuel that the Super BN can
pump, so the only reason to use a large needle valve is to obtain the correct
needle valve and arm spring combination (pop-off) for your watercraft.
So, the manual states you want to use the smallest N/S to obtain the desired pop-off. Does that mean if the desired popoff was 32psi, you should use the 1.5 / 65g combo over the 2.0 / 115g combo?
WFO Speedracer
Alabama
The reason for that is that the smaller needle valves have greater resistance to vibration,which in turn make the carbs easier to tune and stay in tune.
Foximus
CFL Cheapass.
Oviedo, Fl
On a side note. I have 4 springs laying here brand new from a rebuild kit. They are identical to the pictures posted in length... but now the gold is longest.
From longest to shortest, I have
Gold
Silver
Black
Silver
I cant tell a difference between the two silvers. Is the shorter the spring the higher the pressure? I'm shooting for a 20-25 psi pop on dual 44s.
Never Mind. Turns out I have the old style kit with Gold 115's
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Gold
Silver
Black
Silver
The dull gray/silver 95 gram springs will have only 1 turn of closed loops at the end of the spring, all other have 2 1/2 turns of closed loops at the ends of the springs... that makes it really easy to spot the 95 gram spring compared to the shinny silver 65 gram spring which is also a tad shorter.
Note: You can see it in pic of post #2 by DAG.
Midlake Crisis
Bakersfield, CA
I want to know the answer to this too - I was looking at the jetting database and it seems like EVERYONE is running the larger N/S.
I have a 2.3 now but am about to freshen up my carb and am thinking about switching to a 1.5 I have on hand, as the Group K tuning manual recommends. Thoughts?
Pablo
sqeez bth levrs & lean bk
georgia
Great post with the documents/springs. Thx.
What's the method/tools for checking actual pop off? I've been told you can use a small, cheap bicycle pump and whatever else???...to check pop off. Can someone give post a "how to" on this topic?
