I'm new to SJ's so please bear with me.
This "extra" fitting on my head pipe is for??? Water injection? The ski is not equipped.....so what do I do with the fitting, other than put on water injection?
Which chamber is this? From the weld to the end it measures a little over 2".
Opinions on this colling line routing:
One line coming from pump to a water strainer
Strainer to exhaust manifold (2 fittings on the manifold T'd for the single line)
2 fittings on WC head:
Front fitting to water injection (?) fitting (You can see in the pic, this isn't a regular barb fitting. Rather it is a fitting that something would screw onto.)
Rear head fitting to normal upper head pipe fitting
Lower pipe fitting to left side of T #1
Center of T#1 to Pipe chamber (with FCV in between)
Right of T #1 to right of T #2
Center of T #2 to hose flush
Left of T #2 to pisser
Hope that makes some sort of sense.....
Any help is appreciated!
On a side note, I would NOT reccommend using pressure washer hose for cooling lines. The PO used this for the line over the chamber, I guess due to heat exposure. It was difficult to remove the lines since the braided wire had rusted to everything it was connected to.
