yamaha girdle hardware
Mouthfulloflake
ISJWTA member #2
NW Arkansas
is it possible to get long studs instead of the case bolts and head girdle bolts?
ive got a girdle head, and NO hardware.
im trying to figure out how to get this stuff without breaking the bank.
long studs would also make assembly a WHOLE lot easier I think.
any ideas?
advice?
Thanks in advance!
WaveDemon
Not Dead - Notable Member
Hell, Florida
any ideas?
advice?
Thanks in advance!
I've seen it done before. I think that's what magoo does if I understand you correctly.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
Now, if someone just knows that thread Diameter and Pitch, Ill price the studs locally or from Mcmaster Carr, or Grainger.
I can remove one later and find the thread/pitch, but I figured someone might know.
also, hardened stainless?
or what I wonder.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
mcmaster carr doesnt show them in stainless ( long enough)
local supply shop only has 300 series threaded rod.
Might be cheaper to order the $69 kit from atjetsports, or the $75 from ADA.
need to check Grainger and a few others.
also, Im guessing the length is 11 inches or so?
280-300mm
am I way long there?
Mouthfulloflake
ISJWTA member #2
NW Arkansas
I will call Paul and ask him, if I buy id rather buy from him.
I can get some threaded rod locally ( stainless), but I guess that would be pretty hooptyfied wouldnt it?
Mouthfulloflake
ISJWTA member #2
NW Arkansas
wax,
1.5 or 1.25?
Ill see what I can find, maybe we can get a QTY price break on the studs.
assuming I can FIND them somewhere.
I could probably have them made locally, I ised to make threaded stainless rods at a shop I worked at, but larger, and SAE not metric.
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Get only S.S. studs from ADA. As I went through a ton of them until they got them right, not stretching and not breaking at the edge where the threads stop. They have a lot more expense in materials now. I can torque them even up to 45 ft-lbs and no worrys with any compression ratio I want.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
thats something I wondered about, ltos of different grades of stainless, and most dont make fasteners worth a damn.
any idea what the alloy of the ADA studs is?
