single vs. dual cooling f/s porting (magoo)
getting ready to drop in my new magoo/LPW motor:
82mm
165psi
2mm static advance
MSD-E
61x fly
single TLR 48
can I get away with just single cooling (split to either side of ex mani), or do I have to add a second dedicated cooling line????
Single is fine I say.
I think dual cooling comes in handy for supplying cool water under good pressure to the headpipe.
RoyalFlush@PCB
Shootin' The Crap
PCB
82mm
165psi
2mm static advance
MSD-E
61x fly
single TLR 48
Why would you want to do this? Your ski's already set-up for dual, so I'd run it. BTW---did you get my pump out of the attic yet? :sneaky:
the mag was set up for dual, but the stock pump im running is just set for single (i think)......
if I need dual cooling, not a big deal...but I still have to do a motor install and redo all the lines and such for this weekend....just didnt want to have to do something else if it wasnt needed...
however, I did install the cooling lines with enough slack to do whatever I wanted with them, so If this weekend she seems to be running hot, not a big deal..then I can change out the pump
i also have a concord to install, but want to try this motor first with the same prop so as to really get a feel for the differnce the motor makes......then will do the prop (and cooling, if needed) next week!
njfl
X-H2
I was just down there in FL two weeks ago riding on Lake Tarpon and was sweating even when in the water. With the higher FL water temperatures, I would suggest dual cooling with a couple restrictors, or better yet, a Jetworks flow control valve. I think in the summer, in FL, you will see a performance difference with the dual cooling. Perhaps it's not as important up north.
crammit442
makin' legs
here
82mm
165psi
2mm static advance
MSD-E
61x fly
single TLR 48
can I get away with just single cooling (split to either side of ex mani), or do I have to add a second dedicated cooling line????[/QUOTE]
This kind of info should be part of the the package. My builder always has very specific specs for cooling, jetting, pump/prop,etc. I'd call Paul.
Charles
RoyalFlush@PCB
Shootin' The Crap
PCB
i think you COULD run that motor all day long with single cooling.
but you know what you SHOULD do here. :)
dual.
Agreed. How hard is it to tap the pump and install a brass fitting? (Spoken like a true plumber.):sneaky:
I don't like to argue with the 'Dok---I saw how he jumped on Slutty in the plug thread. :haha:
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Drill and tap the bottom of 'B' pipe manifold with 2 90/ fittings and then run short waterlines back to the firewall with a 'T' fitting for your single cooling line for now, That way when you do plumb for dual cooling that part is already done. Run 2 outlets on the head and 'T' them back together for a single outlet to the pipe 'in' fitting...this way you cool both cylinders very even and helps the jetting of both cylinder the same with a single line set-up.
SkiDaddy
Just Havin' Fun!
Orange City, FL
Did you ever see my melted piston from sucking up shells?:woot: With dual lines if you suck up a piece of coquina in one line you can see the difference & still be able to ride back normally...:cool2:
Also, when I do a long tailstand in the summer & the water gets on your sunburn it's uncomfortably warm :bigeyes: even with dual cooling.
RoyalFlush@PCB
Shootin' The Crap
PCB
What you are suggesting would be TWICE as much work as Idok is willing to do right now. :biggrin:
He has a manifold that is already drilled and tapped. He also has a MAG pump in his ATTIC that is setup for dual cooling. He wants to run a stock pump that is not setup for dual cooling---all he needs to do is ONE tap. :banghead:
To the best of my knowledge, the motor is out of the ski allowing for this job to be EVEN EASIER if he'd flip the hull over. :pat:
On a threadjack note---Chucky, I have only talked to you on the phone once awhile back, probably don't remember me---I have Derek Stein's old Wamilton ski with one of your INCREDIBLE 5mm stroker motors in it and I just wanted to say, "Thank You!!!! You Rock!!!" :biggthumpup: :Banane01:
Jr.
Standing Tall
Staff member
Hot-Lanta
I always suggest duel cooling on ported motors, just for insurance sake. But espically so in Fla.
Please make sure you do the duel cooling!:smile:
