pics of your trailer
B-Roy
Makin' a Comeback!
MICHIGAN
It also has a dirtbike ramp in the middle, that way I can go to silver lake and jetski, and ride the dunes:)
SuperJETT
none
Are you building from scratch? If so, Dexter Torflex axle is my recommendation. Mine is over 11 years old now and still smooth as can be. Independent torsion arms, completely customizable.
Here's a shot when it was new back in '95:
It's been revised since then, moved the skis forward, new bow stops (get Stoltz polyurethane, there's a thread on where to get them now), ditched the aluminum box for a plastic one that doesn't RATTLE or cover everything with aluminum powder..
The main frame is 2x3 galvanized H-beam, fully welded, all hardware is stainless, including the skis/tiedowns/handle/fender mounts.
Frosty
New York Crew
Western New York
here's mine... last pic is a little empty... since the blaster is gone...
F
Freestyleriverrat
Guest
That trailer is sweet :biggthumpup: On the way to lanier I could not even tell it was back there.............behind the honda accord. He did a killer job on it. :woot: I swear you need to take more pics and do a writeup on that bad boy.
Y
yamaslut
Guest
trailer???? what is that... I thought they just went in the back of the truck...
:cheer:
KEKE
X
France
my ski and my ski friends
Here's mine...kinda tough to see buried under skis and camping stuff.
I bought it from Talsivar for 300 bucks. It's a 3-place for standups, supposedly.
But I have made it work for 4 Superjets a few times now. And some gear on top of it all.
I have also pulled two couches on it across the country.
It's unpainted steel - I should take care of that sometime.
I bought a harbor freight utility trailer for two hundred bucks. Ran 2x4s in the middle for the skies, under that is a peice of plywood for my fourwheeler, dirtbikes, old skool vw chassis, and other misc toys that I can find. Hopefully tomarrow Ill be modifing it to hold 3 new skis.:Banane01: I can pull it behind my vw with no problems. Will try to get some pics tomarrow.
