Cooling Line restrictor
Bobert540
Rockford,MI
Just wondering where you guys are getting/making your restrictors. I need a 4mm restrictor. Is there anything at a hardware store I could use? Sorry having a brain fart and figured I would see what everyone else was using. Thanks!
I've used a 1/8 brass pipe plug, the type that uses an Allen wrench . Just drill through the center, 3 mm might be just right in the winter.
I use the Jetworks quick-disconnect restrictor. It comes with three different sized inserts (2, 3, 4mm) and you can run without restrictors - so four sizes total. Changing sizes takes only a few seconds.
Here's a pic of two of them installed:
SUPERJET-113
GASKETS FOR CHAMP BRAP!
I have dual cooling and in the winter time here I use 2 carb Mikuni brass "seats" that are drilled out to 3mm and then I just hose clamp them in the lines exiting the head. Those seats are the perfet size to slide inside water line.
Ive never seen those JEtworks ones. nice!
#ZERO
Beach Bum
Florida - U.S.A.
You can find 3/8-inch or 10mm diameter nylon standoffs at any local hardware store that can be installed inside the cooling hose right before the pissers fittings and they come in different hole sizes.
