Christian_83
Xscream
- Denmark
So, after reading a bit on:
http://www.x-h2o.com/index.php?threads/diy-total-loss-on-a-budget.166929/
and
http://www.x-h2o.com/index.php?threads/msd-enhancer-vs-protec-modded-cdi.183691/
I discovered that @waxhead had found a very nice fully programable Ignition box, that could do everything "we need" and then some.
http://www.zeeltronic.com/
Is making CDI or ECU boxes, almost to what ever need one might have. is fully programable through usb and PC or handheld programmer. Can be 1-3 cylinder controller.
Im 99% sure that is that box, the JSTL is using.
Would there be any interest in a a box, that would replace the MSD TL box. ideally so all other MSD parts could be used. pickups, pickupplate, flywheel and coils?
If the pickups is not useable, might need to switch to hall effect sensor, and replace those with the MSD pickups.
Im trying to figure out whats possible. Im just curious if this could be done easy and cheap. Im not here to make money.
The Box that im looking at now, is retailing at 220euro wich is roughly 270 USD.
and
