DIY Total loss or MSD TL upgrade box 270USD?
Quinc
Buy a Superjet
California
I am running the wax curve now with 170psi compression. Thinking about increasing the curve some. We have 91 octane here.
Idaho
I'm curious if there is much to gain by bumping the timing. I have the wax curve with only 154psi compression. Bumping my compression is probably the bigger opportunity for me. I only have 91 as well.
More compression and more timing if you want the most out of your motor.
I run 93 octane on 32 degrees advance with about 230 psi compression. But that’s just me.... don’t take that was a recommendation.
Roseand
Ready to RIP
Wisconsin
Honestly I'd ask your engine builder what they recommend. Depending on your compression, porting, pipe, pump load, etc a curve might not be right for everyone. It's never fun when you toast a motor because you were trying to squeeze every ounce out of a pump gas setup.
waxhead
wannabe backflipper
gold coast
The curve I wrote will work fine on pump gas. I made it like that on purpose. Its a pretty tough curve you can change it if you like but i dont really see the need to
OCD Solutions
Rentz, GA
I got to play with my first Zeeltronics unit today thanks to ScottS and Sanoman and it was everything I expected. Nice strong spark, dead simple to connect and even easier to connect to and program.
We sacrificed a Stator cover to the milling machine gods and carved out a window to view the timing marks, then played around with some MSD timing strips before we got things dialed in. We were able to successfully map out the Wax curve so I am confident that the test rig is accurate, or at least within half a degree anyways.
Now, why is that important you ask? Well, because the second thing we did today was to swap in a stock 64X CDI and map out it's curve.
I can't count how many times I have been asked to do this but I can finally report, the deed is done and results will be posted once I get a chance to sit down and enter them into a curve.
waxhead
wannabe backflipper
gold coast
Thats awesome, Im very interested in seeing what you get for the 760 curve
Put me down as another person very interested in seeing the 760 oem curve, I'm amused because I feel like the value of a used 760 oem cdi is about to bump up or down a bit. I selfishly hope they have a decent curve because I want to steal one of my zeeltronic units from a Yamaha to put on a 750 kawi.
V-town
on the third lump.. you could swap plug wires around and make your front cylinder have the retarded timing ? I thought they were a wasted spark system and they (OEM) fired even not on a power stroke.
waxhead
wannabe backflipper
gold coast
With out the third lump.
You need to take the 3rd lump off at this stage to make it work. I did draw a flywheel and send the drawing to Borut so he can change it so you dont need to remove the lump. you can just switch it between 2 and 3. im not sure where he got to on that
OCD Solutions
Rentz, GA
Is that curve with or without the third lump?
When we first mapped the 64X CDI, we recorded a flat curve of 12deg. I was about to post my results with some questions when I remembered the third lump. I dug up another flywheel that still had the lump and was able to record the posted curve.
The OEM CDI has to see that third lump to function correctly.
Rowdogg50
Rowdogg50
Fresno
