NITRO C-1 Visual Carbon Hull by DJR Ltd
Stockton
Question fir you guys, what are all the conicle washers and screws going around both sides of the bottom deck for ? Thanks
Hi Harbor,
The hull you see there is the prototype of the Nitro.
For surf, we planned to add a full length sponson to the ski to make it more stable for surf, but we were so pleased with the stability on flatwater, we only needed to add front sponsons and rear fins to the hull for big surf (which our surf rider Dan Foy has since thoroughly tested). For our surf hulls, you can have this option you see fitted, but it will only have these for the front area (where a sponson would usually go). But you do not need them to be able to retro fit sponsons for surf.
Cheers!
