P&P performance aka PhilipClemmons
Joined
Jun 28, 2007
Harveys Lake PA
I wanted to share my experience with Phil at P&P performance. I bought a TPE 1105 and needed to get it dialed in before daytona, and after the gremlins we had at havasu I didnt want to have that happen again! I left my ski with Phil knowing he had helped Erik tune the original 1105 and it would be right. I had originally thought he would just get the motor running better than I could, I was in for a big surprise! Not only did the engine and total loss get tuned but prop nozzle and tail cone were all adjusted accordingly. Even though he said its only 85% with the time he had before daytona its still way better than I could have done in an entire summer of tuning myself. So if tuning isnt your strong point this is the guy. Have a look at his builds, some of the cleanest work I have seen. From now on if I need my ski tuned I know where its going. Had I done this on my last setup I would have had a lot more time to ride instead of second guessing myself wondering if I had everything right.
The only bad thing I can say is now my ski is way too much for me and im going to have a learning curve this summer when it hits the water again!
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Joined
Dec 5, 2010
Wasaga Beach
I have never met Philip in person but I did spend a bit of time with him on the phone last summer when tuning my ski. He also took the time to help me out with my AG charging system. It doesn't take long to realize he knows his stuff.
Joined
Aug 24, 2006
VA
If you've got limited time and have to pick riding or wrenching, get P&P to build it. It'll be built like a show car (you've got to see his drag car), tuned, and reliable. The more time you spend up front to build it right, the less time (unless you meet a sandbar) needed down the road. Remember pay now, or pay later...
Joined
Jan 14, 2006
Tuscaloosa, AL
I met Phillip at Daytona, His ski's were immaculate. His strap system for his battery was an ingenious idea for when you have to remove the battery alot, he had it out in a minute. This was in his KDX, tucked back in the back corner.
Joined
Jun 28, 2007
Harveys Lake PA
Been getting a bunch of texts and pms about what it costs. Im sure it will be case by case so you are best to contact Phil directly.
Joined
Jul 6, 2010
wichita, ks
i would like to see this strap system you speak of??
NVJAY775
My home away from home.
Joined
May 3, 2009
Gardnerville, Nevada, United States
Bump for a bad a$$ tuner and great guy. I picked up a TPE 964 SS and told Philip basically everything about the rest of my ski and he dialed me in without even seeing the ski. Jetting, initial air screw settings, compression for my elevation, pump set up etc... I'm at 5,000' and he nailed it. Super difficult feat to even get close to IMO.
He's very easy to contact and was willing to help get me dialed in. I wish I lived closer, just so he could take a spin on my ski and see what a good job he did on it.
If you want to get your ski tuned properly, he's the go to guy, hands down.
Thanks Philip! You da man buddy! Lovin my ski.
hink320
Joined
May 28, 2012
sask, canada
I have been chasing my tail for a year trying to get my Dasa 1200 performing the way I feel it should. I messaged Phil asking if I could talk to him about tuning it, he sent me his number and I called and talked to him a couple times. We went over basically everything about my setup over the phone and he had me check a few things, including pressure testing my PFP chamber, and low and behold my water jacket is busted. He talked me through converting it to a wet pipe and gave me some different jetting specs. I took it for a ride yesterday and all I can say is wow!!! This is how it was supposed to feel from the start, my motor has never had this much power or ran this well. Instead of nosing in flips, I was finally going plate to plate....however with the new found power I tired out fast, it's a handful now. I still have a lot of fine tuning to do, getting the water injection to where it should be and fine tuning the carbs, but I finally feel like I'm on the home stretch.
Joined
Apr 5, 2012
marion ohio
Big thanks to Phil for taking time on a holiday weekend to help a couple of guys from Ohio out. I'm amazed at how quickly and accurately he can diagnose a problem. The man is incredible.
Joined
Jun 28, 2007
Harveys Lake PA
Phil is really making a name for himself! Give it a year or so I can see him tuning a winning boat at wf. Some people say they can tune and guys like this just go out and do it. Glad you guys had a good trip. I remember just a few weeks ago talking to you about heading to see him.
Joined
Apr 24, 2012
Marion, Ohio
+1 for this guy. I took my 1105 Brawler down to him with 102nd7 last weekend for some tuning. He was able to figure out the issues I was having and had my setup tuned within an hour. I would definitely take my ski to him again if I change some stuff and need some additional work!
westjon86
Blast eet!
Joined
May 8, 2012
Philly
Had to add to this. I visited Phil last weekend for an MSD TL install and tune and I was blown away. The attention to detail and quality of his work is second to none. I sent him the MSD components ahead of time to wire and mock up and came down to have him install on my footrocket. I switched to the TNT pipe and waterbox and no longer had room for my limited slip tank. He installed one of his special battery mounts for me and helped me mount a jaz tank. He took the time to listen to my questions and make sure I had a good understanding of how I can make changes to the ski to move the powerband around to my liking as my skills progress. I'm just an average joe, not a professional or competition rider and really appreciated the time he took to make my ski right. I wouldn't hesistate to have him do work on my ski again. Thanks again Phil.
