Running a RRP pipe with PF water box
Has anyone run a RRP pipe with a Power Factor water box? How are the results?
I have access to them both for almost free.
Friend had the RRP setup, Pipe and Box, It let water in the motor everytime he stopped. never seen anything like it. He ended up selling the ski before he found a solution. Few peeps I talked to all said, Swap to a PF Waterbox.
I have no issue with that. Moving the exh exit higher inside the hull at the firewall is easy fix. Mine is just crazy loud minimal baffle. Seeing if anyone has had better luck with others
Another member told me he ran the Jetmaniac box as a solution to water intrusion and he said it was quieter too
I would not want to do that to a brand new AM Hull!!!!!! He was looking at different hoses that created a "hump", but sold it instead to go back to a flatwater hull.
He gave me a good deal on a hull. He ain’t that tight.....lol.
so it looks like lim slip is making them for jm. If not those welds sure look familiar.
