‘96 B1 Paint Code
WFO Speedracer
Alabama
Same thing happens on the bottom of Kawi hulls , it's because they spray paint directedly over unprepped SMC , no sanding , no primer , they might as well be spraying over Pam cooking spray.
I had the same year ski, same color , luckily I already had some red that was a really close color match when I did mine .
Thanks Mike! I have to do mine as well. Approximately how much paint do you think I need to do the red on the hood like you did? Also, are those aftermarket or OEM decals? If they're aftermarket, who did them? I need a set.
Mike W
Infidel
North Florida
I only bought a pint I believe. Only used about 5-6 ounces of it and I layed down 3 coats.
The “Twin Carb” and the “Yamaha” decals on the bottom part of the hull are aftermarket from Exotic Signs. The rest are still oem. They are very close to oem and very good quality.IMG_4409.jpegIMG_4407.jpeg
WFO Speedracer
Alabama
1/2 of a pint would be more than enough when reduced but you will have to see what quantities your local supplier can actually mix up for you.
That turned out great! Were you able to buy just the lower graphics from them or did you have to buy the whole kit?
