00 Superjet electrical
We replaced the coil, plugs and heat sensor due to an issue last weekend. When taking it apart to replace them, I ziptied 3 ground eyelets together and 2. I photographed everythings location etc.
We hooked it all up tonight and the ski fires, sounds aggressive and mean. BUT it will not turn off. Wont start without the lanyard in, but if pulled or the stop button pressed, nothing. I had to yank the plug wires to kill it.
I replaced the screws to the Ebox grounding inside. I checked every plug from the MSD to the wires, all good. I tried the old coil just cuz. I tried it with the heat sensor disconnected.
I do not know where else or what else to test. Unless the kill switch just crapped out at random after being hooked up...I am at a loss because that worked prior to these parts installed. The wires are nicely color coded and I only unplugged 4 wires. Orange to Orange, Braided black to the MSD black....Pink to Pink, Black of the sensor to the black with the grounding eyelet.
