06 Superjet no spark issue
Hi guys having an issue with my 06 superjet Not getting any spark. I pulled the ebox apart to check some things. Checking the orange wire going to ignition coil and I am only getting 30vDC. I then checked the white/red stripe to black from stator and only getting 2 to 5vAC. Checking brown/white to black I am only getting 30vAC.
I pulled the flywheel cover and found a decent amount of oil in the bottom of the cover and cavity.
I understand there's most likely grease from the starter but I didn't expect oil. Is this common or should I be concerned?
Based on the voltage, I think the stator is ok, but possibly CDI is the culprit. What voltage output are you guys seeing from CDI to ignition coil? (orange wire)
Thanks for any help.
ok now that the weekend is over and everyone is done riding ;), anyone have any suggestions or ideas?
If anyone has their box apart and could give the CDI output voltage to ignition coil (orange wire) that would be great.
Oh and yes i have tried disconnecting black/white connector...No luck
Thanks
