08 sj shaft is it the same as a blaster
is the blaster shaft the same as the new 08 sj shaft ?
if so dose that mean my blaster pump will fit straight into an 08 sj and vise versa ?
ItsRixter
SoCal Wav Jumping shiznit
Sunny Diego
I don't believe the B1 and 08 SJ are the same. Although the 08 and newer SJ's do have longer shafts it is not as long as the B1. 08+ SJ are about andinch longer and B1 shafts are about 2 inches longer than the 96-2007 SJ
I remember when skat first made the set back magnums for the super jets they said to run the blaster shaft. Later they did their own. The skat is considerably stronger.
